mf-35 hyd
`ric
07-31-2005 17:09:56
when i first start out with my mf35 using a brushhog it lifts it up all the way with ease . but after i run it for awhile and get everything good and warmed up it wont pick it all the way up anymore. any suggestions. RICK
Big Dean
08-01-2005 07:11:19
 Re: mf-35 hyd in reply to `ric, 07-31-2005 17:09:56
That problem is usually because the pump is worn. Those tractors built before 1964 originally used MF M1103 Tran/hyd oil in them it is an 80/90 wt mineral oil. It can be replaces with GL1 80/90wt oil GL 1 is a mineral oil. It is OK to use the thinner oil used in the tractors built from 1964 and up if your hydraulic system is in good condition but if not the lift will not lift with it after the oil gets hot. If you have the thin oil in yours replacing it with the 89/90 wt Mineral oil will probably make it lift after the oil gets hot. The 80/90 wt is US specs the UK specs is 40 wt but it is still the same oil.
