2 speed trans mf 135 gas
D Rose
07-30-2005 19:48:33
Can anyone tell me the fix for a trans that wont go in low and jumps out of high range.. what is the best cure for making the 2 speed shifter work>>
Big Dean
07-30-2005 21:28:29
 Re: 2 speed trans mf 135 gas in reply to D Rose, 07-30-2005 19:48:33
There is a ring that has splines inside it and knurled on the outside. That ring is pressed into the center hub of the two speed planetary. the ring will work out and it will not let it go all the way in to high and it is for low. I have repaired dozens of them. you remove center hub lay it flat on the front face then drive the ring in till it is flush with the end of the hub. then spot weld it in the seam of the ring and hub in about 3 or 4 places the welds each need to be about a 1/4'' long. be careful not to weld on the spline area you need to check the shift collar will go in the splines. You may have to file them a little with a three cornered file. I have detailed pictures showing how to make those repairs. If you would like to have them send me an email address I will email them to you.
