Mf 135 noise in pto
rick
05-01-2000 02:49:45
can anyone help me I have a 135 with a 3cyl perkins a friend has been using. when i got the tractor back when the pto is put under load there is a loud grinding noise in the gearbox like a shaft is not meshing properly pto is still driving .I am in the Northern Territory of Australia and would greatly appreciate any ideas. if anybody has a workshop manual with a diagram of the pto assembly a copy of the page would be a great help as I hope to repair this problem myself Thanks Rick
Jim Nisbet
05-01-2000 07:51:54
 Re: mf 135 noise in pto in reply to rick, 05-01-2000 02:49:45
Two pins or dowals hold the pump in place it could be on or both have broke. I once heard a tractor make a noise like you describe and that was what it was. These pins are held in place by two nuts each side of transmission case down low in line with shaft, when you find them remove side plates and put hand in and feel around to see if there is movement.
