ENGINE STOPS RUNNING
RODNEY M.
07-26-2005 18:32:23
FIRST I LIKE TO THANK ALL OF YOU FOR THE INFORMATION ON POLARIZING A GENERATOR..THANKS..
I HAVE THIS PROBLEM WITH MY MF-165 ONNCE IT STARTS, IT WARMS UP,RUNS FINE,BUT AFTER A WHILE LETS SAY 30 MIN. OR AFTER IT READS MEDIUM TEMP. ON THE INDICATOR IT SOUNDS LIKE IT IS STARVING FOR FUEL THEN THE ENGINE DIES..I HAVEPULLED THE FUEL LINE OFF AND FUEL FLOWS FINE,I HAVE DRAINED THE TANK LOOKING FOR OBSTRUCTIONS,BUT FOUND NONE..AFTER THE TRACTOR HAS COOLED DOWN I AM ABLE TOMOVE HER BACK INTO THE SHOP..I HAVE NOTICE THE ENGINE DOES RUN HOT. WHEN IT SHUTS DOWN IT MAKES A BOILING SOUND, I HAVE CHANGED THE THERMOSTAT. THANKS FOR ANY SUGESTIONS.RODNEY.
old
07-26-2005 19:05:52
 Re: ENGINE STOPS RUNNING in reply to RODNEY M., 07-26-2005 18:32:23
Sounds like you may have a coil going bad.
Lou
07-27-2005 09:45:41
 Re: ENGINE STOPS RUNNING in reply to old, 07-26-2005 19:05:52
I had a car do that years ago. I believe it was the coil,cheap enough to try. good luck. Lou
