MF 185 6 Spool Valve Replacement
Pappey
07-24-2005 10:19:05
I have been scratching around for awhile trying to get some leads, Big Dean has offered some suggestions, but I haven't been able to come up with a solid solution.
Basically I need to replace (or repair) the control valve assembly. Its a Hydreco unit, but I'm willing to consider a replacement as long as I don't have to buy/build a lot of hydraulic lines.
Anyone have any experience or suggestions?
Jeff J
DavidP, South Wales
07-24-2005 14:00:02
 Re: MF 185 6 Spool Valve Replacement in reply to Pappey, 07-24-2005 10:19:05
Presumably this is not a standard part. If you have to buy another valve, why not remount it somewhere that it does not obstruct any inplements you use and fit QR couplings onto the valve block unless of course most of your applications are permanently piped. That way you only have to worry about the supply and return lines.
Hope this helps
DavidP
