MF35 power steering problem
Jan Carter
07-23-2005 18:15:16
Power steering fluid leaks out of gear box when tractor steering placed under heavy load.
Have replaced seals in steering column, gear box and steering cylinder piston area.
Any additional suggestions?
Big Dean
07-23-2005 20:02:22
 Re: MF35 power steering problem in reply to Jan Carter, 07-23-2005 18:15:16
The polish rod from the cylinder to the rack did not have a bow it did it I have seen that and it will cause the seal for the polish to leak I have been in to a few of them that a seal was put in with the lip of the seal was facing the wrong way.
Jan Carter
07-24-2005 04:44:03
 Re: MF35 power steering problem in reply to Big Dean, 07-23-2005 20:02:22
Thanks for response. Will check the rod for bow. My understanding of the seal installation, is that the lip should face the pressure side. Is this correct?
