1130 Massey
Dave Diehl
07-21-2005 20:48:11
Dad has a Massey 1130 that appears to be dumping raw oil into the combustion chamber. Its smoking enough to kill skeeters a mile away. The engine is not missing, in fact the oil pressure is toward the top end of the gauge. What is the chance of the seals in the turbo leaking into the intake side of the manifold? The turbo was a factory rebuild installed about 4 to 5 years ago. My other thought was that the oil return side may be clogged and not allowing the oil back to the engine and pressurizing at the seal. I would guess a cracked ring to have a severe drop in compression, that doesn't seem to be the case. Just an "extreme" amount of oil consumption, all the way out the exhaust pipe. Anyone with similar issues? Its running in the pics.
Dave Diehl
07-21-2005 20:50:19
 1130 Massey in reply to Dave Diehl, 07-21-2005 20:48:11
Link is where the pics are located.
jogl
07-22-2005 03:27:54
 Re: 1130 Massey in reply to Dave Diehl, 07-21-2005 20:50:19
Sounds like the same thing my 175 is doing. On my 175 the oil is leaking down the valve stems. The oil leaking down the intake side gets burned, she's smoking like your's, and the oil leaking down the exhaust side is getting blown out the exhaust.
Running 1100 rpm cultivating (running easy) she'll go through more than a quart in a 10 or 12 hour day.
She just turned 6000 hrs so I'm hoping to do an engine job on her this winter, if not she'll have to wait another year to kick the smoking.
If you think that yours may be doing this and want varify it take off the intake manifold and look in. On the 175 I can see the oil on the valve stems real easy, lots.
JP.
Dave Diehl
07-23-2005 08:56:25
 Re: 1130 Massey in reply to jogl, 07-22-2005 03:27:54
I'm thinking that its not valve guide leaking, the reason I say this is that the turbo allow more pressure in the intake area than the head will have in it. This would blow the oil back "up" into the head. My plan is to take the fresh air intake tube off the turbo and take a look inside. That may not happen til next week, but I'm leaning toward the turbo seals. So far I have emailed 2 Massey dealers and neither one has sent a reply. Looks like finding a dealer who wants to sell parts is getting more difficult, and the nearest dealer to me is 52 miles away.
jogl
07-24-2005 03:00:44
 Re: 1130 Massey in reply to Dave Diehl, 07-23-2005 08:56:25
That makes sense. The first step is definately to do a little poking around.
I don't have experience with turbo problems yet so can't offer many ideas there.
Good luck.
