baler
LynnAK
07-20-2005 18:57:31
the dog coming up from underneath the hay chamber, the plunger is running into it. What makes the dog work what do we do to make it stay down?
Big Dean
07-20-2005 19:30:49
 Re: baler in reply to LynnAK, 07-20-2005 18:57:31
The Baler is out of time you need to get an operaters manual for it they will give you the procedure for timeing the baler. or if you can post the brand and model of the baler there may be someone on here that can tell you how to time it.
LynnAK
07-20-2005 19:53:25
 Re: baler in reply to Big Dean , 07-20-2005 19:30:49
I've posted another message for timing instructions. Yesturday it was working like a hot damn, got half the field done, left it as was then today it didn't get far before it broke the sheer pin. I don't know if the needles are supposed to be up or down when it's already been baling and there's still a bale in it. I know they're supposed to be down when it's empty. What seems to have happened is the plunger came down and broke the pin, we've just done a jbweld job (because it's caste) and hoping that will hold, if not we'll have to buy a new needle. It's a Massey-Ferguson and it says on the serial plate #10. Would that still be the timing? or should we have made sure the needles were down before each time we start?
onefarmer
07-21-2005 20:13:20
 Re: baler in reply to LynnAK, 07-20-2005 19:53:25
Sounds like your knotters tripped while the machine was shutting down or just starting up (going around an end?). Happens to me sometimes. Sounds like you will need a new needle. They do take some of a beating, more then JB will take. Or try welding it, if someone is good with cast it can be done.
