MF 165 Air Filters-Removal
Steven Kotula
07-20-2005 03:58:15
Recently purchased MF 165 and am going through it. I cannot get the top of the air filter canister off. There is a bar that looks like it should just slide out but it only slides so far and I don't want to reef on it ( someone has replaced what was the handle with a bolt so I'm sure it's challenging to take off). Any suggestions on this simple job would be greatly appreciated.
Don-WI
07-21-2005 21:23:34
 Re: MF 165 Air Filters-Removal in reply to Steven Kotula, 07-20-2005 03:58:15
That bar only slides one way, and you need to back that bolt (or screw that's supposed to be in there) out a ways. If it doesn't slide enough to one side to pull the other side out, try sliding it the other way. There is a tab on one side that prevents it fron sliding too far. The original hand-screw that is supposed to be in there has about a 1" cup that contacts the filter. Your Massey dealer just might be able to get you a new one if you ask. Donovan from Wisconsin
