MH 30 Overheating
Dr. Chris
07-18-2005 08:59:56
30 overheating when under light load. Pulled out thermostat, and still overheats. Radiator looks very clean. Could it be the water pump. It doesn"t leak or anything, I"ve never known a water pump to just stop pumping. If I run the tractor there doesn"t seem to be anyflow through the radiator. I"m just looking down into it though.
msb
07-18-2005 21:12:11
 Re: MH 30 Overheating in reply to Dr. Chris, 07-18-2005 08:59:56
An old misconception that it is a water pump.They should have been called water circulation pumps from the start since all they do is circulate coolant.Fill the radiator to where you can see the water and look to see if you can detect any water movement.I would suspect the radiator needs rodded out.
