Bought the MF50
Dan S (NY)
07-17-2005 17:07:47
Went and looked at the MF50 yesterday. Serial number shows it�s a 59. Has the Z134 gas engine and it fired right up and ran good with no smoke. Steering was good and tight, clutch and hydraulics checked out fine. The brakes could be a little better, but they do work ok. No sign of leaks at the bell housing or either axel and just a little damp at the PTO. After some driving around and warming it up, compression test showed 125 across all cylinders. All gauges where working and Tach/hourmeter shows 3100 hours. Tin is pretty good with only the hood ornament and one side of the grill missing. Its got 14.9 x 24 rears on it and one is almost new and the other still has about 70% tread left. Took it home for $2000. Can�t wait to go get some work done!
Dan
Lou
07-18-2005 06:53:22
 Re: Bought the MF50 in reply to Dan S (NY), 07-17-2005 17:07:47
Sounds like a real good value. Good Luck Lou
