front wheel bearing MF 175
Lou
07-09-2005 09:02:14
I have the new bearings, and ill try to keep track of how the old ones come out.But some time there in pieces. Any pictures or tips? Thanks Lou
DavidP, South Wales
07-09-2005 14:41:39
 Re: front wheel bearing MF 175 in reply to Lou, 07-09-2005 09:02:14
Hi Lou,
Make sure that!
The welded on cup on the kingpin is in good condition to keep out dirt.
The seal is fitted true and that the sealing area on the kin pin is smooth. Make sure the outer bearing slides smoothly on the axle spindle.
Fully grease bearings during assembly. Fit hub and wheel and adjust up slowly until play disappears then fit split pin or back off the nut until you can do so.
Cheers
DavidP
Lou
07-11-2005 06:56:57
 Re: front wheel bearing MF 175 in reply to DavidP, South Wales, 07-09-2005 14:41:39
Thank you Dave with luck Ill be at it later today. Lou
