New Ignition
RandyR
07-08-2005 18:44:07
Well I got my Pertronix system installed. Simple installation. Runs good. Nice to know I won't have trouble with a bad condenser, or replacing points. Even though it ran ok before, it seems to runs even better. This set-up will give more dwell time, which makes the coil perform better. It's like in the old days when converting to dual points was the hot set-up. It gave the coil more time with power going through it (dwell), which gave a hotter spark. So does the Pertronix, I think.
It blue smokes a bit after start up, then clears up when warmed up.
Compression test was good (140), does it sound like valve seals?
Jerry/MT
07-08-2005 20:54:34
 Re: New Ignition in reply to RandyR, 07-08-2005 18:44:07
Sounds like seals and valve guides.
