massey 135 throttle lever
TOMMYBOY
07-08-2005 12:53:39
I HAVE A MASSEY 135 THAT THE THROTTLE LEVER WONT STAY PULLED BACK UNLESS YOU HOLD IT.I DONT SEE ANY KIND OF SET SCREW OR FRICTION WASHER.AM I MISSING A SPRING?
DavidP, South Wales
07-08-2005 22:37:55
 Re: massey 135 throttle lever in reply to TOMMYBOY, 07-08-2005 12:53:39
Hi,
There is a bracket bolted to the rear of the battery box which supports the lower end of the throttle lever. Underneath is a friction washer and limit plate. There is a nut (3/4 spanner) to adjust the resistance on the lever.
Cheers
DavidP
TOMMYBOY
07-11-2005 05:18:15
 Re: massey 135 throttle lever in reply to DavidP, South Wales, 07-08-2005 22:37:55
THANKS FOR THE INFO DAVID NOW I CAN KEEP BOTH HANDS ON THE WHEEL!
