mf-50 hydraulics bleed down fast
hank n tx
07-07-2005 17:32:57
the hydraulics on my mf50d bleed down as soon as i shut it down. they also bleed down some when i step on the clutch. what needs to be done to fix this. is it a difficult job.
thanks hank
Big Dean
07-08-2005 09:51:36
 Re: mf-50 hydraulics bleed down fast in reply to hank n tx, 07-07-2005 17:32:57
You have a leak somewhere in the hydraulic system The thing I found it to be most times was the pump control valve but it could be a standpipe O-ring a relief valve the lift cylinder or a combination of all of them.
txgrn
07-08-2005 05:08:07
The hyd pump on the MF is PTO (input) shaft driven so you have to have the pto clutch engaged to get the pump to run.
Bleed down is usually fluid leaking by the rings on the lift piston. A good half day job but not mechanically taxing. I have done Fords, but not MF. Should be similar. Seat off, lift arms that go to the lower 3pt arms disconnected on the top end, lift cover off (2 man job). Turn her upside down on the bench and you should be looking at it.
To get the piston out (if like Ford) using light air pressure, find a port to open and stick compressed air on it. Not a lot or you'll blow the piston across the shop.....just enough to get it moving.
Mark
