massey ferguson 50c backhoe
Todd Clay
07-06-2005 13:35:40
I have a 1978 50c backhoe Iam having some problems with the hydrulics i have had all the cylinders repacked even the rotary on the hoe. but all the cyclinders want to move.when not running the hoe the
boom wants to rotate to the left or right any ideas
how to sovle this problem.also I can not locate the links and guide for the bucket and I need a bucket to. thanks todd
Thomas
07-07-2005 13:40:20
 Re: massey ferguson 50c backhoe in reply to Todd Clay, 07-06-2005 13:35:40
Probably the shock valves in the valve block. These relive the pressure when you slew and let go so that you don't break anything with the pressure spike. I'm pretty sure that they are in the spool but may possibly be inside the rotary cylinder. If other cylinders are creeping then your spool block is probably worn.
