MF 135 Tach and Temp Gauges
Rich K.
07-02-2005 17:57:22
Hi Guys, I have a couple of questions. Maybe someone out there much smarter than I am can help me with them. I have a MF 135 diesel. I put in a new temp gauge and a new tach with a new cable. I also installed a new oil pressure gauge. The oil pressure gauge works fine. For some reason, I can't get either the temp gauge or the tach to work. Does anyone have any ideas? Thanks for your time.
RandyR
07-03-2005 05:56:42
 Re: MF 135 Tach and Temp Gauges in reply to Rich K., 07-02-2005 17:57:22
Hi Rich. What kind of temp gauge do you have, mechanical or electric? If mech you could check for a pinched capillary tube, or make sure the sensor end is in a hole that has contact with coolant, or the gauge could be faulty.
If electric, check the hole as before for coolant, check wiring and connections. For the tach, where does it read from, the back of the genny or alternator, or a point on the engine such as the back of the camshaft? If it's gear driven through a cable maybe the drive is stripped at the gears. I found that before, I just glued it back into the hole in the little gear with Metalset, JBWeld works too, maybe even crazy glue.
DavidP, South Wales
07-03-2005 07:58:20
 Re: MF 135 Tach and Temp Gauges in reply to RandyR, 07-03-2005 05:56:42
Hi,
Randy is on the right track. If you have an electric temp gauge remove the wire from the sensor and earth it at a clean point. If the electrical side is OK the gauge to go to fully hot. This will isolate where the problem is. Also remove the sensor and you should have a good flow of coolant, do this only when cold. If you have little or no flow, insert something into the hole to clear any blockage.
Cheers
DavidP
