massey 255 hydraulics
weston
07-01-2005 07:26:11
the other day i was moving 1000lb round bales with my loader on my 255 and when i tried to tilt the bales back the remote hyd. control stick on the right of the seat would kick off.
is this normal?
Big Dean
07-01-2005 09:47:31
 Re: massey 255 hydraulics in reply to weston, 07-01-2005 07:26:11
Those valves are set to kick out when the auxiliary hydraulic system pressure reaches 1900 to 2100 PSI you loader may take more pressure than that to lift the 1000 LB. bales or the kick outs may need to be adjusted or you may have something wrong in the valve causing it to kick out before it reaches the set pressure
MF#1
07-01-2005 07:36:14
When used to raise/lower with a "stop" ours will automatically kick off, i.e., discing. That load(1000 lbs) "may" be tripping it off. Hyd fluid level good?
