hyd. flow and capacities MF165
flem
06-30-2005 06:01:19
does anyone know the hydraulic pump flow #s for the MF165's
DavidP, South Wales
06-30-2005 12:49:40
 Re: hyd. flow and capacities MF165 in reply to flem, 06-30-2005 06:01:19
Hi,
These figures are fo UK spec MF 165's.
Ferguson (linkage pump) 3.1 gal/min 14.1 ltrs
Pressure available on later tractors 3000 psi
Multi-power pump 6.3 gal/min 28.6 ltrs
Combined pumps 9.4 g/min 42.7 ltrs at 2000psi
MP pump 8.8hp Combined 12.9hp.
Hope this helps
DavidP
flem
06-30-2005 15:10:04
 Re: hyd. flow and capacities MF165 in reply to DavidP, South Wales, 06-30-2005 12:49:40
I'm going to rebuild the hyd. pump on my MF65 diesel w/ multipower and uses the .98" blocks and pistons from the early 165's as they had the same hyd. parts just larger .98" pistons vs. the .91" pistons of the 65. I wanted to get a flow increase #.
