1130 hot starting
Reaver
06-29-2005 15:14:18
I have a Massey 1130 diesel...runs like a big dog, but shut it off hot and it won't start until it cools off? Cranks over great, just won't hit a lick? Once cooled off...fires right up!
Any suggestion appreciated :)
Thanks Reaver
cobroller
06-29-2005 17:44:25
 Re: 1130 hot starting in reply to Reaver, 06-29-2005 15:14:18
Sounds to me like the metering valve in the injection pump is sticking. I would try a couple of quarts of Dexron atf in the fuel to help lube it. The next time you get ready to shut the engine off kill it with the brakes instead of the shut off cable. If it will start hot then its the metering valve.
peter danastas
07-08-2005 03:07:29
 Re: 1130 hot starting in reply to cobroller, 06-29-2005 17:44:25
Try pouring cold water on the injector pump when it is hot. Then try starting it
