Pertronix news
RandyR
06-27-2005 16:32:03
Well more news about the Pertronix conversion. I had bought a kit #1145A, and found it didn't fit. The plate was too big to fit in the dist. But that is the one that's recommended. I called Pertronix tech line and found that it's made for a dist with a screw down cap. Mine is a clip on type.
The right one is 1143. I placed an order with Genessee, they knew what the right one was. So I can hardly wait for delivery. They seem like good folks to deal with.
txgrn
06-28-2005 05:17:04
 Re: Pertronix news in reply to RandyR, 06-27-2005 16:32:03
Be sure and pay attention to the primary circuit resistance. You need about 3.5 ohms of resistance in the primary ckt with 12v, half that on 6 volts. Some coils are marked such that "No external resistor needed". Those will measure about 3.5. Others will measure about 1.7 and will need about 1.7 ohm "ballast" resistor in series to limit the switching current for the electronic points.
If you don't have adequate resistance you will fry your switch (electronic points) and it will stay shorted (like points staying closed all the time) which makes your coil get very hot and obviously it won't fire the plugs.
I know because the other day I was troubleshooting a neighbor's tractor. His had a coil with an internal resistor and hence the tractor didn't have one. I took the coil and trigger mechanism from another tractor and installed it. It lasted about 2 minutes.
Trouble shooting later, I found that I had put in a 1.7 ohm coil and not having an external resistor to make a total of 3.5 ohms, I fried the electronic points.
$100 down the drain trying to help a neighbor. Oh well.
Mark
JerryMT
06-29-2005 10:58:53
 Re: Pertronix news in reply to txgrn, 06-28-2005 05:17:04
Pertronix is very specific about making sure that you have 12V to the switching circuit. It's OK to have a ballast reistor in the coil circuit to reduce the coil voltage, but the electronics in the distributor has to be at 12V for proper operation.
txgrn
06-29-2005 15:35:30
 Re: Pertronix news in reply to JerryMT, 06-29-2005 10:58:53
This is easily accomplished if you have a 3.5 ohm coil (i.e. ballast resistance internal or other means internal to limit current to 12v/3.5 ohms = about 3.5 to 4 amps).
With that rig, you can run the red wire to the + terminal on the coil which is getting 12v via the ignition switch and the black wire goes to the coil - terminal.
Otherwise, if you have a ballast resistor, you have to add some wire to the red lead (insulated connections and wiring) to get on the battery side of the ballast resistor to get the 12v required.
Not getting 12v won't kill it. It just may not run properly. Not having adequate circuit resistance WILL kill it... BTDT.
Mark
RandyR
06-28-2005 18:27:16
Mark: Thanks for the heads up. I checked my coil with an ohm meter and it is 3.5 ohms. No external resistor. Good to go. Sure wouldn't want to fry the module!
One question. The Pertronix is supposed to be used with a "point type coil", not an electronic type. How would I tell and what is the difference? Thanks.
txgrn
06-29-2005 15:29:45
 Re: Pertronix news in reply to RandyR, 06-28-2005 18:27:16
Got me. Dunno the difference. The coil doesn't know how you are going to switch current on and off. Only thing I can think of is that they are using that terminology to indicate the presence or absence of the external resistance.
HTH
Mark
