MH 30 running problems
Dr. Chris
06-27-2005 07:18:50
My MH 30 will only run on full choke now. And even then it won"t go over idle. This happened basically out of no-where. I checked all gas lines and passages, in and out of the carb. No blockages or anything. Is there a way to set the float height on these tractors. I"m guessing it"s a fuel starvation issue.
Dr. Chris
06-29-2005 20:13:28
 Re: MH 30 running problems in reply to Dr. Chris, 06-27-2005 07:18:50
Thanks for the feedback, I'll be sure to check all of this and I'll let you know how it goes. Can't wait for the weekend, hopefully I'll be able to use it, I have a list of things to do.
Bruce Colbourne
06-27-2005 21:39:40
I had the same problem with my 55 and the problem was in the feul tank.The stand pipe on the sediment bowl in the feul tank was plugged.Just one more thing to check.
old
06-27-2005 07:42:28
The carb probably need to be rebuilt, if you have tried to do so and it still does that it means you have missed something in the main jet area of the carb.
Dr. Chris
06-27-2005 12:41:40
 Re: MH 30 running problems in reply to old, 06-27-2005 07:42:28
I did check the jet and passage thoroughly , I will check again. Just to make sure that I'm not missing anything there is only 1 jet in this carb, is that correct? Maybe something been lost through the ages.
Farmall
06-27-2005 18:37:36
 Re: MH 30 running problems in reply to Dr. Chris, 06-27-2005 12:41:40
My tractor did the same thing . I cleaned the carb 10 times. The problem was that the tip of the main needle valve had broken off and ever so slightly restricted the flow of the fuel to the metering stem.. Hope this helps
