1100 brakes
hammerstrap
06-25-2005 20:17:57
I had the line under the hood wear through yesterday.....so I brazed it. Now the right brakes stays locked if you touch it. The only other thing I did was tighten the line for the right side as it had a seep.
Any suggestion as to what I did or what happened?
Thomas
06-26-2005 02:19:23
 Re: 1100 brakes in reply to hammerstrap, 06-25-2005 20:17:57
You've probably blocked the pipe with braze, so that you can force fluid past with the pedal pressure, but return springs are not strong enough to push fluid back through the gap. Replace the pipe.
