1953 TO 30
Cappoman
06-25-2005 12:58:43
I was out bush hogging today, and noticed that the temp was staying around 200 degrees. Is this too hot? There is no thermostat in the system.
Was a warm day here, in the high 80"s to low 90"s. The grass/weeds I was hogging were pretty tall, maybe waist high or a little higher.
marlowe
06-25-2005 18:44:35
 Re: 1953 TO 30 in reply to Cappoman, 06-25-2005 12:58:43
200 this border line. preassure wash the radiator fins may look clean but is most likley pluged. is fan belt tight ?
Ray,IN
06-25-2005 21:49:51
 Re: 1953 TO 30 in reply to marlowe, 06-25-2005 18:44:35
yep! Cleaning the radiator is a huge factor in avoiding cracking your block. Open the hood and clean the radiator from the engine side with water or air pressure. Avoid the fins! Bent fins also hinder cooling. Is the carb adjusted properly? Harry Ferguson tractors use the fuel to assist with cooling under heavy engine loading. This means the engine will run rich without load, a normal condition.
