M H 22 engine oil in hydrallic system
Nate Stangl
06-23-2005 22:55:30
The other day using our 22, we splattered the hood with oil out of the top of the hydrallic can in front of the radiator and were down 2 quarts of engine oil. How can this happen? The motor is in good shape.
Alberta Mike
06-25-2005 16:29:57
 Re: M H 22 engine oil in hydrallic system in reply to Nate Stangl, 06-23-2005 22:55:30
Well, if it has factory hydraulics, the hydraulic pump is driven off the front right side of the engine (cam gear drives the governor which in turn drives the hydraulic pump). Engine oil lubricates that cam gear and the governor gear and governor parts inside. The hydraulic pump mounts right up against the governor gear but it should be sealed off from engine oil. It is self-lubricating with the hydraulic oil from the hydraulic system. You are right about it being confusing. It would seem that the hydraulic pump is allowing engine oil inside of it at this mounting location. Take off the hydraulic pump and see what it looks like at that "join" location.
