JERKY HARD POWER STEERING
NORMAN
04-27-2000 20:12:09
HELP!!!, I HAVE REBUILT THE CYLINDER, TRIED ADJUST THE ROD ON THE CYLINDER, REPLACED THE ROD ENDS, DRAG LINK AND CHECKED FLUID LEVEL, BUT WHEN I TURN THE STEERING WHEEL, ITS TIGHT, THEN JERKS AND START TO TURN, BOTH DIRECTIONS, IT DARTS SO BAD, I CANT RUN FAST, AND DONT EVEN THINK ABOUT GETTING ON THE HI WAY. I AM FAIRLY MECHANICAL, SO I NEED TO HERE FROM SOMEONE THAT IS FAMILIAR WITH THIS PROBLEM AND HOW TO FIX IT. THANKS IN ADVANCE ,OH BY THE WAY...THIS IS ON A MASSEY FURGERSON 165
Danny
05-04-2000 13:15:28
 Re: JERKY HARD POWER STEERING in reply to NORMAN, 04-27-2000 20:12:09
Check for sloppy pin holes in the ends of the turnbuckle thst pushes and pulls the steering control valve on top of the cylinder. Also make sure that the tapered pin with the slotted end and locknut is backed out enough to allow the valve to move before the steering starts to work without the help of the power steering.
Bob in virginia
04-28-2000 14:32:57
Norm, you may want to take a quick look at JACK in NB response on 4/24/2000, now located on page 3 or 4 on this site. I was impressed with his detailed response to another problem and in it you may find a clue. Good luck!
