MF 50 Loader Removal Questions
Matthew Roybal
06-22-2005 07:13:23
I just got a 1963 MF 50 Which is in very decent shape overall except for the way the loader is rigged. It's hooked up to the rear hydraulics, and performs very poorly. I've decided to take it off, and get rid of it. Do I have to remove the isolator valve?? Do I need to do any kind of modifying on the rear hydraulics plumbing, or just plug the holes? How much could it be worth? The cylinders don't leak or anything, it's just that it needs to run off a good auxilary pump. Thanks
i wish
06-23-2005 12:25:47
 Re: MF 50 Loader Removal Questions in reply to Matthew Roybal, 06-22-2005 07:13:23
i do not think i would get rid of your loader. i just wish my 35 had one!!!!!
Big Dean
06-22-2005 10:48:19
Hi Matthew You do not have to remove the isolator valve when you remove the loader just plug all the ports in the valve. If you set the isolator valve right you can use the position and draft lever in the quadrant to operate the three point lift. If I can be of further help email me.
Lou
06-22-2005 11:42:26
 Re: MF 50 Loader Removal Questions in reply to Big Dean, 06-22-2005 10:48:19
Mathew I own a 50 with a loader, handiest machine I have. You can put a front pump on her they work good when done properly. Just a thought. You might be throwing the baby away with the bath water. Good luck, Lou
Matthew Roybal
06-22-2005 15:39:15
 Re: MF 50 Loader Removal Questions in reply to Lou, 06-22-2005 11:42:26
I thought of that, but how much is a pump? What do you do about the resevoir??
mlm
06-22-2005 15:58:20
 Re: MF 50 Loader Removal Questions in reply to Matthew Roybal, 06-22-2005 15:39:15
I have a 150 that has a pump on the front. It draws oil though a pipe T screwed into the transmission drain plug. The return oil dumps in the fill plug. I think it would have been better to return the oil though a fitting put on the side cover.The pump mounts on a dealer suppied bracket, made by Freeman, I think. The shafts and joints had to be made up. we replaced the pump for $110 from Surplus Center.
Lou
06-23-2005 05:58:20
 Re: MF 50 Loader Removal Questions in reply to mlm, 06-22-2005 15:58:20
Mathew Im sure no mechanic but there are plenty on this sight,they can point you in the right direction if you ask enough questions. I love my 50 with a loader. Lou
Matthew Roybal
06-23-2005 07:11:13
 Re: MF 50 Loader Removal Questions in reply to Lou, 06-23-2005 05:58:20
Well, Thanks guys, I'll post that question. Definitely something to think about before I take it off.
Doug Burns
06-24-2005 12:52:58
 Re: MF 50 Loader Removal Questions in reply to Matthew Roybal, 06-23-2005 07:11:13
I have a MF50 with a loader. The pump is mounted to the front PTO. The pump takes a suction from the reservoir built into the loader frame. I need a pump if you happen to find a place to get one.
