Wagon options for a Pony?
pgmrdan
06-21-2005 05:17:32
Now that I have a MH Pony what are my options for some sort of wagon or trailer to pull behind it? (Dumb question?)
Right now a wagon or trailer would be the most useful addition to my tractor.
I had thought about getting a small utility trailer to pull behind my pickup and also use it to pull behind the tractor on the property.
What are some other options besides welding up something myself? What would be a good size for hauling firewood, landscaping material, etc.?
51Pony
06-21-2005 17:21:27
 Re: Wagon options for a Pony? in reply to pgmrdan, 06-21-2005 05:17:32
Wagon for this Pony is made of an old truck axle and frame. Put a new pressure treated body on it on '99 after it sat in Gramps barn for 35 years. Wouldn't even hold the oats that the mice kept tryin to hide in it. It's 8' long, 4' wide and 3' deep. Hauls 3 yards of garden mulch, 1-1/2 yards of topsoil, bales of straw, currently full of a chunked up tree that was threatening the power lines. Pony works hard with that much soil.
Rod in Smiths Falls, ON,
06-21-2005 15:09:59
I have eight utility and boat trailers in the farmyard at the moment, and the one I could not do without is a solid, 2000 lb-axle 4 X 6' with a tailgate (with chains like the old pickups) and sturdy 13" tires.
Everyone comments on how robust this particular trailer is: it's made from fairly heavy steel and I can put 400 pounds on the extended tailgate without bending it or the chains I bolted to the sides of the box.
I tow it behind everything from my SUV to a succession of golf carts. It makes frequent trips to the quarry for a yard of gravel or sand per trip. It got dragged through the mud behind tractors all spring. Of course it is useful for hauling wood, fence posts, planks, planer shavings, 50 gallon drums, etc.
It is a mobile workbench. It is easy to manoeuvre in tight quarters and store because of its short length.
Remember that a utility trailer doesn't have to do everything: 90% will be just fine, and most loads are well under a ton, so think small.
Be sure to put a jack on the front of it. Your back will thank you.
