mf-210 trans. oil level
michael b dipie
06-20-2005 19:08:54
I just purchased a mf-210 tractor and it runs very well. I want to change the transmission oil but there is no level indicator stick does anyone have any ideas. I have another question on the tachometer it says to run 540pto. on the tach it runs the tractor at 2300 rpm I need alittle info on this thanks mike.
brownie570
07-20-2005 19:09:24
 Re: mf-210 trans. oil level in reply to michael b dipierro, 06-20-2005 19:08:54
MY 210 I FILL UP BY SIGHT, I LOOK DOWN THE FILL PORT AND ONLY FILL IT ABOUT 1/2 TO 3/4 UP TO THE FILLER HOLE, THERE IS A BREATHER BEHIND THE SEAT , IT WILL COME OUT THAT CAP IF YOU OVER FILL IT. MY 210 HAS ABOUT 3500 HRS ON IT AND I FILL THE TRANY ALL THE TIME (SLOW AXLE LEAK)NEVER HAD ANY PROBS WITH THE TRANY FILLING IT THIS WAY.
brownie570
07-20-2005 19:04:17
540ptp is the rpm of the pto drive if you set the rpm guage at the mark on the rpm indicator.I have a 210-4 with a loader, my front rim is bad, might you know of any one with a used one?
