fuel in air filter hose
kpage
06-17-2005 14:51:37
fan blade broke off on my mf65 and went into the radiator, so when i took it apart to have the radiator recored, must have been a gallon of fuel inside the the air cleaner hose. Any idea why and could this be the problem with the back firing after i run it for an hour or so? also i need a fan blade any ideas where to get that?..once again thanks to all that help and all the other posters that i get info from just reading this great forum
Oldfarmboy Jim
06-19-2005 23:29:50
 Re: fuel in air filter hose in reply to kpage, 06-17-2005 14:51:37
Check to see if your float valve isn't stuck open. You could shut off the valve at the sediment bowl each time you shut it down, if that's the problem. Sometimes they stick once in a while, then they'll be fine for a time.
kpage
06-20-2005 13:48:56
 Re: fuel in air filter hose in reply to Oldfarmboy Jim, 06-19-2005 23:29:50
thanks for the help
Thomas
06-19-2005 05:46:19
Replace the thermostart (cold start) unit, it will be leaking fuel into the manifold.
