MF 65 PTO Clutch Problems
MLJ
06-13-2005 10:01:39
The clutch on my 65 is acting up. I have no problem changing gears, but when I move the clutch down into the second stage and try to engage the PTO it just grinds. I can get the PTO engaged if a turn off the engine and shift it in. It looks like the threaded rod attached to the clutch pedal has been adjusted as far as possible. Anybody have an idea of what the problem is?
MLJ
06-15-2005 05:20:20
 Re: MF 65 PTO Clutch Problems in reply to MLJ, 06-13-2005 10:01:39
Thanks for the help. I got it fixed last night by adjusting the free travel.
2x4
06-13-2005 22:43:07
go to this site search box & type in "pto grinds" & click it. Scroll down to # 19 & click it. then click the link to Big Dean's site. Its all laid out there.
MHF
06-13-2005 15:10:40
First how much free travel are you running I"d try 1/8 inch. pins on adj rod are they worn If needed drill out and use bigger pins. Play in those pins causes this. If there okay pull clutch cover off bottom look at the release finger can you see where it pivots does that pivot pin seem worn? You can replace those without spliting tractor. If those are okay check clearence on 3 bolts within pressure plate not on release finger, there should be eighty thousandths between bolt head and plate you can set alittle tighter try 65- 70 thsdths if you want that will shorten travel and might be enough let me know if you need anymore
