M-H 44 BR?
William Brown
04-27-2000 10:18:20
Does anyone know what the "BR" on the model means? This tractor has a propane tank mounted for a fuel tank. The three point is homemade, and it has a single front tire. I would like to identify it so I can get a manual and parts list.
It runs good, but the clutch will not disengage.
Tom
05-04-2000 15:42:09
 Re: M-H 44 BR? in reply to William Brown, 04-27-2000 10:18:20
William: Butane (C4H10) has slightly less BTU's than Propane (C3H8). BTU's is the energy derived from heat. In layman's terms the tractor would run richer with propane if it is set up for butane, but the difference is small. To make the tractor correct for propane the fuel inlet orifice would have to be about 2.2% smaller in surface area. Not 2.2% smaller in diameter. I'm not sure if the regulator pressure would be correct for both fuels. I would consult a propane dealer that converts autos or trucks to propane. Tom
Tom
04-27-2000 18:34:28
Butane,Row Crop
William Brown
04-30-2000 17:30:01
 Re: Re: M-H 44 BR? in reply to Tom, 04-27-2000 18:34:28
Does this mean that this is a factory gas installation or an after market installation? And since it is butane, do you know if is it alright to use propane?
