Massey fuel leak
lapp
06-13-2005 04:22:38
I have a 1080 Massey that is leaking diesel into the crank case some where. I replaced the lift pump thinking it could be a bad diapham but that wasn"t the problem. I assume the only other place it could be leaking is through the injection pump. Any one have any suggestions, perhaps seen this before?
DavidP,South Wales
06-13-2005 14:40:24
 Re: Massey fuel leak in reply to lapp, 06-13-2005 04:22:38
Hi,
It is possible for fuel to leak from the main pump into the crank case if the seal has split or hardened. It will require a full strip to rectify.
Before doing that remove the thermostart from the inlet manifold and check for any dampness around the coil element.
A leaking thermostart normally causes excess white smoke but a continual slow leak might be enough to raise the oil level.
Cheers
David P
