Subject: MF 150 piston bearings
tractorgreg
06-12-2005 15:15:06
Name: tractorgreg If this is your regular "handle", you can reserve it for your exclusive use by creating a password below. Set Password: Report Handle Misuse E-Mail: [email protected]
Body of Message:
I removed an oil pan on a z145 Continental engine and found metal parts from what appears to be a shattered oil sling. Why would that shatter? One of my piston bearings seized is why I took the oil pan off. Do the grooves on the cover for the bearings line up with one another. It appeared that some of mine were line up on top and bottom and others weren't.
I would like to replace the oil sling without pulling the engine. Can I remove the front of the axle from the engine and go after it from the front pulley? Thanks
