MF 135, 1974, Perkins engine crankshaft thrust bearing
jj
04-27-2000 06:23:43
Has anyone experienced a problem with the crankshaft thrust bearing going out on this tractor. I have lost the thrust bearing twice in a very few hours of run time. Any help would be appreciated. Thanks..jj
Jack in NB
04-27-2000 13:14:20
 Re: MF 135, 1974, Perkins engine crankshaft thrust bearing in reply to jj, 04-27-2000 06:23:43
jj -
The diesel Perkins will take out thrust bearings if the clutch free play is too tight, or the operator keeps a foot on the clutch pedal.
Keeps forward pressure on the thrust bearing.
Is this a possibility?
jj
04-28-2000 08:01:24
 Re: Re: MF 135, 1974, Perkins engine crankshaft thrust bearing in reply to Jack in NB, 04-27-2000 13:14:20
Hi, Jack
The tractor is used with a 90" finish mower. I operate the tractor. I don't think I ride the clutch, but the clutch is hard to push in. (disengage) I thought this might be a factor. I had the motor completely rebuilt in the summer of 1998, I found the crankshaft had excessive end play in the summer of 1999, I had the thrust bearing repaired, now the start of 2000 the thrust bearing is out again.
