mf35 starts, stalls
freeland
06-08-2005 18:14:22
mf35 z134 eng. will only start with choke closed, then run a little bit with it pulled out an inch or so. engine will rev hi, then low, then after a minute or so will die. This all while sitting still under no load. have rebuilt the carb,installed new plugs, wires,and coil. cond and points seem ok, getting good spark.recently thouroughly cleaned oil bath assy. fuel flows freely, no obstructions in lines, filters look good.also once in a while it will backfire. any sugg or should I just park it and put up a for sale sign...Last week I managed to back it up and put the box blade down and it was all I could do to get it back to the shed. any sugg?
Arthur from Tassy
06-09-2005 04:08:48
 Re: mf35 starts, stalls in reply to freeland, 06-08-2005 18:14:22
Hi freeland
I would go along with what OLD has said, A couple more things to watch out for could be, 1. the needle and seat can stick shut stopping fuel flow.
2. some rubbish moving around in the tank (like rust particles) blocking the hole of the tanks fuel line.
3. Are the pilot and main jets adjusted correctly? if these are screwed up too tight, your caburettor will give a lean mixture and cause the motor to back fire and die.
Cheers Arthur from Tassy
old
06-08-2005 19:37:02
Sounds like you still have a problem in the carb, they can be tricky to rebuild. A back fire from the carb says its lean on fuel which also means the main jet is also clogged still.
