135 power steering
Greg Thomas
06-08-2005 10:12:24
The power steering works good until the tractor has been run a while then it only "power assists" occasionally.
What is causing that?
I recently bought the tractor and know very little about it. It appears to have car type transmission fluid in the power steering system.
Thanks, Greg
Big Dean
06-09-2005 09:35:42
 Re: 135 power steering in reply to Greg Thomas, 06-08-2005 10:12:24
When the oil companies switched from the old Type A ATF to the Dextron ATF we had a service bulletin from Massey Ferguson for all tractors the one in the United States anyway. It said to replace Type A ATF oil with the same oil used in the transmission at that time it was M1129A today it is called Permatran 3. The bulletin said the seals used in the MF tractors were not compatible with Dextron ATF fluid. The problem you are having sounds like a weak power steering pump. Changing to the Permatran 3 oil could help this as the Dextron ATF gets so thin when it gets hot it will bypass where the Permatran 3 won't. Hope this will help If I can be of further help email me
DavidP,South Wales
06-08-2005 13:51:28
Hello Greg,
The system operates by meeting resistance when you turn the wheel which in turn activates the PAS. Seems like you have wear (excess travel) in the actuating collar at the top of the steering column, and or the ball joints. Occasional operation may be caused by the position of the steering.
The oil that you mention is the normally red automatic transmission fluid (ATF) which is correct although I believe it has now been superceded in the US at least.
Cheers
David P
Greg Thomas
06-10-2005 05:06:33
 Re: 135 power steering in reply to DavidP,South Wales, 06-08-2005 13:51:28
Thanks for the info.
I am going to change the fluid as suggested. It has a fairly new, aftermarket pump on it but the tractor has been used a good bit.
Greg
Greg Thomas
06-10-2005 05:10:21
 Re: 135 power steering in reply to Greg Thomas, 06-10-2005 05:06:33
David,
What do you mean by ball joint? Is it what I would call tie rod ends?
