MS135 quadrant support
gn052
06-08-2005 04:15:33
quadrant support cracked rendering hydraulic lift almost inoperable. Can it be replaced w/o removing
hydraulic lift cover which appears to be major operation
Big Dean
06-08-2005 09:22:52
 Re: MS135 quadrant support in reply to gn052, 06-08-2005 04:15:33
The Liftcover has to be removed. There is a screw that holds The quadrant support in the liftcover on the bottom side. You may have some lift linkage out of place inside you should check before you put the liftcover back on. If I can be of further email me
