3 pt linkage lifting capability of MF 590
phil eldridge
06-07-2005 07:43:37
what is the max I can lift with the 3 pt linkage and drive comfortably with on a 2wd 1978 MF 590, i want to use the tractor with a pan type concrete mixer. will wheel weight help. the tractor has a front loader.
DavidP, South Wales
06-07-2005 11:49:30
 Re: 3 pt linkage lifting capability of MF 590 in reply to phil eldridge, 06-07-2005 07:43:37
Hi Phil,
The lift capacity at the lower link ends for the 2WD MF 590 as given in the 1980 MF Pocket Catalogue is 2227 kg or in old money 4900 lbs. If the tractor has a loader fitted, you'll have all the front weight you need as long as you keep a bucket or fork fitted and keep it about three feet off the ground. You can always put something in the bucket if you need to.
Cheers
DavidP
