MF 65
Greg A
06-06-2005 07:12:09
I just picked up a MF65 and don't know much about these tractors, my other 2 tractors are JD. I have a couple of questions: There is a small hole +/- 3/16" on the bottom side of what appears to be the transmision housing and a cotter pin has been placed through the hole from the inside of the housing, the pin is loose in the hole and a small amount of oil is dripping from the hole, was this done at the factory, what is the purpose and where is the oil coming from. Is there a way to hook up a remote hyd. cylinder for loader or pull type implements. Also is there any things I should look for on the tractor that may need attention or give me problems.
Boss Hog
06-07-2005 03:57:44
 Re: MF 65 in reply to Greg A, 06-06-2005 07:12:09
Check out Big Dean"s website. It has lots of info about your tractor.
http://hometown.aol.com/bigdean62/index.html
DavidP, South Wales
06-06-2005 11:02:42
Hi Greg,
The split pin is there to allow any oil to escape but prevent the ingress of water etc. The idea being that oil will drip until empty. First of all what colour is the oil? If it is black, it's engine oil passing the rear crank seal. Not a major problem unless the leak becomes significant. If it is 'clearish' oil then it is probably coming from the gearbox input shafts, input housing loose on the case or botton blanking plate. If it's engine oil the tractor will have to be split, clutch and flywheel removed and the seal replaced. If i's gearbox, a major strip down is required. No prblem mounting external valves as Lou says. You can either bolt on an isolating valve in place of the plate under the seat or tap into the cover at the front on either side. Your return line which should be larger bore than the supply can be fitted in place of the filler plug next to the gear lever.
Only real problems with the 65's were the dry disc brakes. Check carefully for one side 'grabbing' under gentle pedal pressure. In bad cases you may have to reverse slightly to free it. If you have this problem you will need new actuators.....a bit expensive.
Good luck
DavidP
Arthur from Tassy
06-09-2005 05:20:26
 Re: MF 65 in reply to DavidP, South Wales, 06-06-2005 11:02:42
Hi Greg A
if the oil leak is very slow and the clutch is working ok I would leave well alone.
I have also left a posting tonight (our time AEST 10:20 PM), about brake problem like what David P has mentioned.
Cheers Arthur from Tassy
Lou
06-06-2005 10:39:13
Welcome to the Red tractor family. The pin you discribed is from the factory. You unfortunatly have an oil leak, hope its not to bad.Yes you can mount a fromt pump for loader or remotes under the seat area. Good Luck i think youll like the 65. Lou
