M F 135 float height
Skidder
06-04-2005 02:53:03
Could someone tell me the correct way to adjust the float on a 135 .
Thanks Skidder
txgrn
06-07-2005 16:30:46
 Re: M F 135 float height in reply to Skidder, 06-04-2005 02:53:03
What works for most applications is this. Remove the bowl bottom from the carb (4 screws usually). Open the fuel valve from the tank if you have one. Fuel should run from the bottom of the carb where you removed the bowl. Very very gently push up on the end of the float opposite the pivot. When the float gets level with the carb upper casting you should have just shut off fuel and it no longer runs from the carb.
If not, new needle valve or adjust the float.
Mark.
