Massey-Harris clutch identification
William Brown
04-26-2000 14:24:42
I have a Massey-Harris tractor that I do not know how to identify what model. The clutch does not disengage. The linkage is functioning, so there must be something wrong with the fork or bearing? Do I need to split the tractor to get to the clutch? William
chase
09-04-2003 20:08:28
 Re: Massey-Harris clutch identification in reply to William Brown, 04-26-2000 14:24:42
i need to learn a bit about clutches. can you send me some infomation about clutches
Tom
05-04-2000 15:50:15
Sounds like the clutch disc is rusted to the pressure plate. If it is on your 44 remove the inspection cover on the bellhousing and push the clutch in and see if you can pry or tap the disc loose from the plate. There may be enough room to get a decent size screwdriver to contact the disc at the cresent shaped openings between the bolts that hold the pressure plate cover to the flywheel, It's been a while since I looked at one so this advice may be a long shot. Otherwise you will have to un-bolt the clutch shaft (or undo the chain) and loosed every thing to lift and move the engine forward, probably have to remove radiator, un-pin the clutch rod too. Take the bellhousing off and remove the clutch and free it!
