MF 202 carb has problem with flooding
Puffie40
06-02-2005 22:22:00
I finished wiring the tractor and enjoyed running it, but a problem happened about half an hour after I turned it off. I left the gas on, and went in. then a half hour later, I came back to find the gas dripping from the rubber hose connecting the carb to the filter pipe. When I pulled the carb free, about a cup of gas came along with it.
I think it might be that the float needle is sticking. Any ideas?
Thanks for any help!
old
06-03-2005 08:29:59
 Re: MF 202 carb has problem with flooding in reply to Puffie40, 06-02-2005 22:22:00
Float my be sticking or the needle or you have some junk in the needle seat. You may be able to get it to work right just by tapping on the carb a few times. You also may be able to get the junk out by pulling the drain plug at the bottom of the carb and letting a little gas flow ot of the carb
Puffie40
06-04-2005 00:50:46
 Re: MF 202 carb has problem with flooding in reply to old, 06-03-2005 08:29:59
I don't think it would be crud in the carb, as I took it apart and cleaned it the first time it happened (It happened twice, both times with the gas left on) I would conclude that either the float or needle valve is sticking, or prehaps the float is not at the correct hight.
Could it be possible for the mainjet to form a "Siphon" and continually suck gas?
old
06-04-2005 08:00:27
 Re: MF 202 carb has problem with flooding in reply to Puffie40, 06-04-2005 00:50:46
If you have had that problem before I would say you have some crude in the gas tank and its makeing its way down to the carb. Or you also may have a bad float in the carb, but if that is true it probably wouldn't run right.
Puffie40
06-04-2005 13:10:59
 Re: MF 202 carb has problem with flooding in reply to old, 06-04-2005 08:00:27
Okay. I'll pop the carb off again to clean it out and look at the valve, and then look at installing a in-line gas filter. I'll let you know how it turns out.
