MF 35 Starter Follow Up
Joe Kelly
05-31-2005 08:35:21
I posted a note a couple of weeks ago about my inablility to get the starter off my TO 35 gas tractor. The starter would not clear the distributor (even with it turned away from the starter) once it was unbolted. Here is an undate.
After hours of work I finally had to disassembly the starter (unbolting it from the tractor and then backing out the end plated screws and removing the end cover). I then had to loosen the distributor and turn it away from the starter. Only then would it clear enough, and then just barely!!, to get it off. When seeking a replacement I found that this starter was a "long neck" version. The replacement I was finally able to find was a couple of inches shorter and the fellow referred to it as the "short neck" version. The long neck was apparently used early on and then replaced by the shorter version. The difference between the two starters is on the narrow end that bolts up to the tractor.
For the life of me I am not certain how the original starter was installed unless they built the rest of the tractor around it. Once I got the old one off I had the shorter replacement on in 5 minutes.
Thanks to those who offered their insights.
