MF85 Trans Filler Location
Randy T
05-28-2005 06:09:03
Hi, I have a 1960 MF85 Diesel. Is the Transmisson fluid fill located right next to the gear shifts? I have a couple of Shop Manuals for this tractor but nothing that shows the fill location, just exploded view pictures for rebuilds. The manual also indicates that the Transmission, Differential, Hydraulic Lift and Power Steering are all common to each other and hold 46 quarts. Am I reading this correctly? I wanted to change all fluids and filters before I started using this with my brush cutter.
Any help would be appreciated.
Thanks,
Randy
TomTX
05-29-2005 05:37:18
 Re: MF85 Trans Filler Location in reply to Randy T, 05-28-2005 06:09:03
Randy, recommend you order 3 real MF manuals: Operator Manual, Repair Manual, Parts Manual. They are so much better than the IT manuals. I got all 3 for my MF-690 and it is the best maney I ever spent. You will save at least the cost of the manuals by doing repairs, maintenance, and adjustments correctly.
Randy T
05-29-2005 06:25:43
 Re: MF85 Trans Filler Location in reply to TomTX, 05-29-2005 05:37:18
Thanks TomTX. Thats what I am going to do. I was playing hit or miss on which manuals to buy.
Randy
MoJohn
05-28-2005 08:50:00
Randy, the fill is on the left side of the gear shifter.It will take almost 12 gallons to refill.You also have 2 filters.Your dip stick should be on the right side of your tractor.If you need further info, just let me know.John
Randy T
05-28-2005 09:58:04
 Re: MF85 Trans Filler Location in reply to MoJohn, 05-28-2005 08:50:00
Thanks, That is where I was going to try , but the exploded view showed a spring under the cap. So I was unsure. So Thank You on that. You mentioned 2 filters. The only filter I could find was at the power steering by the radiator. Where are the other 1 or 2 located? I have 2 I&T Shop Service manuals and they don"t show these filters. I had a feeling there were more.
Thanks,
Randy
MoJohn
05-28-2005 16:58:13
 Re: MF85 Trans Filler Location in reply to Randy T, 05-28-2005 09:58:04
the 2nd one is actually a power steering pump strainer and it is located under the inspection plate on the top of the transmission.It is a flat plate, near the hydraulic shut-off valve.
Randy T
05-29-2005 06:30:07
 Re: MF85 Trans Filler Location in reply to MoJohn, 05-28-2005 16:58:13
You have been an incredible help MoJohn. I will be tearing it up today.
Thank You.
Randy
