mtnbikerman / Texas Denny
Dale in Mn.
05-26-2005 13:59:53
Thanks for reply on fuel guage/sending unit setup.I think I will check into the setup that Texas Denny has purchased thru J.C.Whitney.Denny,does the sending unit screw on to the tank with the 5 screws that held the original one on or is it a different style?Is the no. you give from catalog include both sending unit and guage? Thank you.
Texas Denny
05-27-2005 08:37:40
 Re: mtnbikerman / Texas Denny in reply to Dale in Mn., 05-26-2005 13:59:53
Dale, double click on my name and send me an email. I'll send you the ad then.
Texas Denny
05-27-2005 08:36:23
Dale, I don't know for sure as the sending unit is at my ranch. Looking at the picture in the catalog, I see the top of the gauge is a round disk. It requires a 2 1/8" hole in the top of the tank. This is typical for most auto tanks. Out of the center of the disk is the insulated stud for connecting a wire to the gauge. It handles depth from 5" to 27". It is intended for a gasket and a locking ring. Other mounting methods will require modification. I'll send the ad to your email after I return from a luncheon.
Dale in Mn.
05-27-2005 19:43:11
 Texas Denny in reply to Texas Denny, 05-27-2005 08:36:23
I was able to look up the number you gave and typed it in at their web site and it brought it up, so I ordered it. Will try to post once I get it and install it.Might be a couple weeks with holiday in there. Thanks again.
