Massey 50 Cylinder Head Removal
Tim Paston
05-22-2005 07:50:57
I have a Massey Ferguson 50 diesel that has a stuck exhaust valve, and have taken all the head bolts that I can find loose. The sucker still wont come free from the block what am I doing wrong. This isnt my first rodeo so this makes me feel really ignorant please help.
supergrumpy
05-26-2005 11:17:21
 Re: Massey 50 Cylinder Head Removal in reply to Tim Paston, 05-22-2005 07:50:57
I recall Big Dean mentioning the same problem on Perkins
carbon builds up on the studs or something and he has lifted tractor trying to pull head
give him a jingle or check hisweb site
Texas Denny
05-25-2005 07:17:57
Do you have a repair manual for your tractor? The manual will show where all the bolts are. Have you removed the rocker arm assembly? Sometimes there are bolts under the rocker shaft. And lastly, the gaskets do stick pretty hard to the block and head. It generally won't come off easily. But you must be absolutely sure that the bolts are all out before you start prying on it. I like to take everything off of heads with which I haven't had experience. There could even be a bolt or two under the exhaust manifold.
