What did I buy?
tom
06-23-1999 11:15:48
I recently bought a tractor/loader at an auction. Near the loader arm is a plate that looks like it says "model MF34A" This thing is painted yellow-runs great-has a 3 point-is a diesel. Does anyone know where I should look for any numbers to find out what it is. I can't find 34A listed anywhere.
The auction slip just says massey ferguson/loader
I would like to find some manuals for it.
HELP!
Elmer
06-24-1999 02:41:14
 Re: What did I buy? in reply to tom, 06-23-1999 11:15:48
Look on the bottom of the panel in front of the gear levers. Should be a similar tag
M. Smith
06-23-1999 13:11:30
It will take a little more info. to determine exactly which tractor you have. The following tractors used the 34A loader. The MF20C 3cyl. eng with drum type brakes. The MF 30B also 3 cyl. but had a larger rear end equipped with wet Brakes. The 40B had a four cyl. eng. There should be a serial number plate around the lower side of the instrument panel.
