3 point hitch for my NEW to me Model 44
Conrad Stone
05-19-2005 20:36:10
If anyone could please point me to a 3 point hitch kit. I would be so grateful. My Model Number is 44-GR-22331. Also It runs fine, but when I put a load on the tractor it just dies like no gas. Gas is clean and brass screen is in place in the bowl. I will use this tractor to clean my Granny's 50 acre place. So, it will be a a working tractor.
Texas Denny
05-20-2005 15:20:11
 Re: 3 point hitch for my NEW to me Model 44 in reply to Conrad Stone, 05-19-2005 20:36:10
Can't help on the 3 point.
It sounds like a fuel problem for sure. If you disconnect the gas line at the carburator and get good steady flow continuously, you can assume that the tank and settling bowl and line are not a problem. If your tractor had set for an extended period of time, the power circuit in the carbuator may be plugged or abstructed. To fix it, find a rebuilding kit for your carb and do a supper job of cleaning all of those air ports and especially the power tube and needle and seat at the bottom of the carb. Make sure that every channel is open and clear.
