mf 31
d. schrems
05-17-2005 16:59:40
i have been using my mf31 recently to do a lot of brushhoging lately . ocassionally it sticks in first gear. any idea what is causing this? i can usually get it out by playing with the shifter but once it was a very slow ride back to the barn to get it unstuck. thanks.
Radu
05-21-2005 06:40:02
 Re: mf 31 in reply to d. schrems, 05-17-2005 16:59:40
Hi, I'm farmer from Romania and to our farm we have farming machine FERGUSON MF 31 made in 1971. Is a old machine but she help us because another is to expensive. I'ts a good machine.
But in this year we have a problem with 2 belt. I serch in catalogue machine and I indentifi this belt. They are next:
- "schuttler und Reinigungsantrieb doppelprofilkeilriemen 17x14x5170"
- "Dreschantrieb flachriemen 80x4x2440"
If we have this belt, we apreciate if you cood help us.
Best regards,
Radu
Big Dean
05-17-2005 17:06:45
Maybe This will help Cause for Shift lever hang up
The transmission main shaft lever hanging up is very common on most models of the MF tractors. The shift lever is held down by a spring & when you start to shift it you will unconsciously lift upon the lever. This causes the shift lever to go into the other shift fork on the other shift rail. That rail can not be moved because of the lock on the back of the transmission to prevent it from going into two gears at the same time. Once you have both shift rails in the neutral position you can then move the shift lever.If you will use the palm of your hand When changing gears to push the lever into neutral then get hold of the lever to put it in the gear you want it in. Shifting it that way it will not hang on you again. Below is the article from my web site that tells how to get the lever unhung. If I can be of further help Email me at [email protected].
Getting the main shift lever unstuck
Pull your filler plug for the transmission look inside you will see a big gear. Find a level spot shut off the tractor. Push the clutch down & put the high low shifter in neutral to relieve any pressure that might be on the gears. With a long screwdriver or a small pry bar pry the big gear forward if it is hung in reverse. Pry it back if it is hung in first gear. If you happen to go to far it will go in the other gear. You need to get it in the center. You should be able to feel the detent balls pop in the grooves in the shift rail as you move the gear. Through the years I have probably unstuck at least a 1000 of them this way. It is a common problem on the Massey tractors after they get a little wear on them
